Eurocat1005
- Technisat [ TechniBox HD VA ] Receiver for TNT SAT reception
Dual LNB set up for Astra 19.2 & Hotbird Satellite 13 degrees
- East Cheshire
Hello ,
I have recently acquired a Technisat Digit isio S2 Sat receiver but I am currently having a problem with no signal.
I'm attaching a few screen shots to illustrate the problem , my set up is a 75 cm dual LNB for Astra 19.2 and Hotbird 13 degrees.
My other Technisat receivers are all working fine so I know that it isn't a loose cable issue.
I may be missing something that is obvious to somebody else reading this but any advice that you can offer would be appreciated.
I have tried scanning both satellites but I am unable to obtain a signal from either.
Thank you in advance.
