No sound
JackieW
Freesat from dish outside
Isle of wight
I have no sound on my Freesat recordable tried reboot, reset,new lead still the same. Anyone have any ideas thanks
Try a different HDMI port on the television or try with a different television. Check the TV hasn't been set to analogue input for audio. Do you get sound from the TV when using other devices or the built in Freeview tuner?
Hello. Yes I have tried another lead. But need to wait till someone can
help hold TV them I can try a different port. My tv is on the wall
Switch the TV off and back on again. That fixes my occasional no sound.
Thankyou. I left tv off at switch all day/night. Also did same with Freesat box. I have sound now . Thankyou everyone. Freesat helpline never suggested this.
In my case it's something to do with the HDMI sound handshaking when moving from an HD channel to an ordinary SD channel or recording. I only need to switch the TV off and then back on again quick.ly once to sort it out.
But, hey, whatever works!
I occasionally have that problem with the handshaking between the LG TV and the DRW895 SKY+ box - the same solution works!
