- TalkTalk TV
- Worksop UK
I have a customer that requires to talk to his property over a CCTV system, The CCTV recorder has a phono out which can connect to an amplifier to allow the user to speak in to a laptop microphone and the audio is sent out via the phono to a amp.
The customer requires 5 speakers / horns around his property externally, 3 x horns 50mtrs from the amp and 2 x horns 120mtrs from the amp.
Can anyone recommend what type of amplifier is required to power 5 horns, what type of horns are required and also the cable required to give loud enough sound outputs over the distances ?
