Pictorial Setup Guide for DiSEqC Motorised dish installation - Downloadable PDF
rolfw
Believe it when I see it Admin.
Staff member
Promax HD Ranger+ spectrum analyser.
Derbyshire
Here is a little pictorial setup guide.
EDIT. Have now uploaded as a PDF file. Feel free to print it out.
ALSO: How to fit an "F" Connector
Notes about your due South satellite
Although I have used Thor 1W as my due South satellite, this is merely because the longitude of my location is actually 1W. If you are situated further East or West, then find your longitude from somewhere like www.multimap.com or www.heavens-above.com and then look at www.lyngsat.com to find the nearest satellite to your longitude.
If there is not a convenient receivable satellite at your actual due South, then pick the nearest one. To make allowance for the fact that it is not exactly due South, a satellite receiver with USALS/GoToX (once your coordinates have been entered), can send the motor to where it thinks the satellite should be and then you can use the alignment procedure as described in the PDF, the arc should then be near perfect. If your receiver or motor does not have this automatic system, manually drive the motor by an approximate amount of degrees using the scale on the motor body.
You can find out approximately where a given satellite is using this tool.
Happy dish fitting.
Excellent guide Rolfw:-worship
Whos that guy hiding behind the dish? lol
And its not a sticky!:eek:
Sad but I recognise that particular install.:-Nooo
Done for one of the members here I think
L.:)
LOL, very difficult to hide behind a transparent dish. ;)
good you mention about the moteck motor bracket bolts shearing off as i nearly did that
cutting the dish bracket bolts down as that is actually a good idea as it pulled the cables out of my motor because i had the dish too high up the motor
very good guide, pointed out to me things i skipped over
I bet someone will put that on e-bay as an ebook!:-Nooo
It is now unless Rolf wants to unstick it, but why should he want to hide such a good tutorial?
Yes but you look like a pro, do you practice? or just watch too much Tim "the toolman" Taylor talking to his neightbour :-rofl2
rolf, I've a question as I'm about to motorise;
I'm at 8e which means 7e is my reference bird. Now do I line up on that pup at 0 on the motor? Part (most of me) thinks yes but some of me thinks no.
Ta v. muchy indeed - Lee(eeeee)
Yes, Lee, line up on 7E, you can account for the slight offset by setting your receiver with USALS and sending your motor to 7E, that way you will have perfect due South alignment when you find 7E. :)
im just about to do my first motorised install. my question is what should be my reference satellite? my location is chester in the north west, uk. 53.192°N, 2.876°W should i use thor? also i will be using it to view french channels, are there many in the clear? any help much appreciated. great guide by the way. cleared up a lot of things for me.
As per the answer above, use the satellite which is closest to your due South, you could use either 5W or 1W, if you are looking for French channels, then 5W is the one to go for. Remember to offset the motor slightly to account for the difference between 5W and your longitude.
How to fit an F connector
Click on individual thumbnails to enlarge them
The procedure is largely the same for screw on type "F" connectors.
Strip the cable, about 1/4" on both sections
Fold back the braid (For a screw on type "F" Connector, simply now screw on until the dialectic foam core touches the end of the connector barrel)
If you push on the connector now with the foil and it bundles up as in the picture above, strip it off, or a good way to prevent this happening is to turn the connector around and gently twist over the copper screen, this will smooth the edges and allow for smooth insertion of the connector in most cases
Push on the connector with the braid still pulled back over the outer, a warm cable makes it easier
Then crimp.
This style of compression connector if fitted with an "O" ring, is waterproof when tightly fitted, but it is advisable to waterproof with self amalgamating tape, if no "O" ring is fitted or if you are using screw on or crimp type connectors.
location is N64.1, E27.7, could you kindly tell me what would be the best reference satellite? Astra 2 or Badr?
Astra 2, good strong satellite, pick a transponder on the North beam. :)
what transponder should i take from the north beam? ;) im a newbie remember :D
thats a nice guide there thanks, will come in useful !!!
Thanks a lot rolf for this thread and for the first post with details about how to use motors.
I must admit that before reading the post, I never thought that I would have the knowledge to do anything about motorizing a dish, but now I am sure that I can.
After reading more threads about motors, I understand that there are basically two DISEQ models made by Moteck and Stab.
I was considering also a Manhattan, but then I read that it is made by Stab.
Has there been any major players in this arena apart from Moteck and Stab or better specifications and quality ?
Would the receiver be matched to the motor with all the settings and so if another similar receiver is used (or a new image is installed), the motor would have to be reset again ?
There are claims that the motor is not fixed well to the dish and therefore the dish might snap off more easily than a fixed dish and could cause accidents flying off the roof.
My problem at the moment is that I don't have at my present dwelling a lot of space movement eversince they built several high buildings around. In fact I was lucky to have a little spot for Hot Bird so a large arc would be in my dreams.
I might be able to experiment somewhere else, perhaps at friends or relatives roofs, but it will not be the same as at your own home.
So at the moment I am just trying to gather the right information and hopefully one day I can put it to practice.
There are a couple of other makes, but most of the other ones around are clones of the Moteck, Jaeger or Stab (in fact the Moteck was originally a Jaeger clone I believe).
If a dish were to be mounted in an exposed position, then I would be inclined to limit the size to 90cm, I have not yet heard of any incidences of motor arms dropping off, but there is obviously a limit as to how much weight it is sensible to hang off of one. :)
