For Sale Prodelin centrefed / axisymmetrical feed c band and mechanical depolariser
Channel Hopper
Staff member
UK
As per this post. It is 'NOS' new old stock and has been sitting in the garage for about ten years.
Since I have a pair of them (perhaps another lying in a box), this one is surplus to requirements.
This would normally have been supplied with any of the 3m to 3.7m, eight petal reflector systems for use with a CPR229 flange LNB, for single polarity receive ony configuration, and I believe this is suitable for anything with a 0.30 to 0.37 f/d ratio.
You will have to fabricate the metalwork to bolt to a dish as everything in front of the feed was used to set up a Ku band (though for some reason I still have one spare half of the two piece clamp, picture to follow). The dish was a four feedarm design, of course
£100 plus whatever it takes to get to you by insured post/courier, I would hazard a guess about £6.
Thanks for looking
Almost forgot. I have a small number of panels for the Prodelin 3m (series 1304) sitting here as well. Either 0179-135 or 0179-136 I cannot remember which.
Whilst damaged near the centre, some enterprising young upstart with an affinity to resin fumes could use just one of these as a former and build some perfectly good 3m reflector clones by making eight identical items.
Free to anyone that wants to collect.
Images of the single clamp for the feed.
And the reflector panel that has the hole for the feed arm (there is also the one without, but for a former this will do)
Centre fed depolariser feed reduced to £80.
