pchappo
- sky+ multiroom - quattro distribution system wannabe
- London, United Kingdom, United Kingdom
i am looking to replace my current SKY satellite dish with a Quattro LNB (so that i can distribute Satellite and normal TV channels around my house).
I have already got a Labgear multiswitch, and now i need a dish and Quattro LNB installed and cables run to the multiswitch.
The cable run is approx 10M - at first floor height - my house is south facing and where the current satellite is, there is a flat roof (makes installs of the dish easier! The cable needs to run up the side of my house and then drilled through the wall and terminated to the Labgear multiswitch r i have (i have purchased a 5/16 way board) - all other cable runs i would look to complete myself, with the installer terminating them to the multiswitch.
Can you please advise of the costs to install / align the dish please. (you could also quote me on the supply of the dish / Quattro LNB - i was looking at a Triax 64cm solid dish)
Many thanks
Many thanks
- i'll put in the thread a diagram of where i would want the cables terminating to - as i've just thought on that i need 2 (dual) cables run around to the other side of the house from the multiswitch .....
