RAI DAB+ feed from 5 West
Yes, I saw that, reinstalled again, now no such warning but ... still no success. I am wondering about the last message "EOF reached"; any meaning?
Your problem is that nc 127.0.0.1:6969 never connects to VMA DAV Launcher's TCP server.
Try to configure TCP IP to 0.0.0.0 or use your real network card IP.
At 10.0E, I think we have a DAB stream on 10734 H, 8970, 3/4.
All the data I've gathered seems to point to this.
Check the file
I thought you are familar with DAB feeds?
a) you found a data package owned by Eutelsat (which has nothing to do with DAB, it's called IPE)
b) a typical DAB stream is around 1 - 2 MBit, but this is up to 12 MBit on PID 101
c) you are using the wrong tools to analyse the content. Don't pipe to dablin, which only expects a valid DAB stream in EDI or ETI format. Use strings instead (it's even available for Windows) to look for texts
d) you can also use the build-in hex-viewer in Transedit
e) DAB streams at least contain the word eti
Therefore, an analysis has these steps:
a) stream PID 101 to the network or to the same machine with Transedit
b) open Ubuntu on same machine via WSL
c) nc [IP:5018] | strings -16 (I recommend at least 10 or even 16 as lenght)
Then you might get texts like
1 Photoshop 3.0
1 LIGION-TRADITION-HERITAGE
1 DIPTC:01019000:arts, culture and entertainment:customs and tradition:
1 .IPTC:01000000:arts, culture and entertainment:
1 2IPTC:12025000:religion aG
1 nd belief:religious event:
1 "IPTC:12000000:religion and belief:
1 customs and tradition
1 religious event
1 g2mapping/libg2 3.10.12
1 SERGEI GAPON
1 AFP or licensors
1 Catholic beliG
1 evers carry traditional handmade 'palm branches', some of which are up to 10 metres long, as they attend a religious procession during Palm Sunday celebrations in Lyse, Masovian VoivodG
1 eship, Poland on March 29, 2026. (Photo by Sergei GAPON / AFP)
Sorry, but today isn't the 1st April ;-)
Tnx, it was my IP needed.
All DAB muxes appear to run OK except RAI on 5W/12.564 V. What's wrong here?
Sure, 120cm, 4 dB margin, should be no problem for you either.
Works flawlessly on E2, but VMA Dabstreamer not.
IPE was part of Agence France-Presse at 10771 H and, following its dissolution, moved to 10735.93 H
I got the same error: if you look on the bottom of DAB windows you'll see the quality of the channel is "20".
This means we receive a corrupted stream hence the errors in Dablin.
Me too, if i tune RAI TP with any program, i have 100% quality
Is it wrong MIS or PLS handling? Something I should correct?
I don't know, this is what i get:
[18:27:07] Starting tuner via StreamReader.dll...
[18:27:07]   Tuner index: 5
[18:27:07]   Target TCP server: 172.16.0.203:2103
[18:27:08] Tuner started.
[18:27:08] Sending DiSEqC RAW: E0 10 38 FC
[18:27:08] DiSEqC command sent.
[18:27:08] Polarization set.
[18:27:08] NOTE: This DAB helper replacement does not yet apply MISSel().
[18:27:08]       Tuning continues without MIS filtering.
[18:27:08] PLS GOLD code 131070 applied.
[18:27:09] Lock OK.
[18:27:09]   Freq: 12563437
[18:27:09]   SR: 35285345
[18:27:09]   SNR: 13,10
[18:27:09]   RF Level: -44
[18:27:09] TCP: listening on 172.16.0.203:2103
[18:27:09] Waiting for DAB client to connect...
[18:27:09] TS filter installed (ID = 0).
but at the end the quality is 20%
Truth to be told, for this particular TP in EBS i have to scan it 2 o 3 times to get the correct tune with all streams available
I think MISSel() is required. What is the MIS value?
This is what I get now:
Same for me, always quality=20
I cannot test myself, so there is not much I can do.
I would need complete information: does it work with CrazyScan? If so, send me the streamreader.log, but start a new one. Explain what you are doing (what transponder, PLS, MIS, etc.). Explain exactly what happens: does it work for a while or never? I need all details. Then, perhaps, I can fix it.
It works great with both EBSPro & CrazyScan. And on Octagon SF8008 as well.
No idea how to get to the streamreader.log .. unfortunately.
It's a file that is in the same folder
In EBS must activated
In CS main directory
Thanks. I sorted it with VMA ... I hope he'll manage to find the bug.
I have added some instruction on how to play this stream on linux.
RAI DAB 12564V-S11@5.0W​
  • Tune:
    neumo-tune -ctune -A blind -a 8 -r 0 -dU -U0 -f 12564 -pV -S 35293
  • demux:
    neumo-dmx -a 8 --stid-isi=11 --pid 1000 | ts2na --pid 1000 -s 0 | na2ni | dablin_gtk
    Due to bugs in various tools, you may need to try several times until a sync is found
