Trust
Specialist Contributor
- 1.2 m Echostar at Twotec twinrotor with lnb changer
- Nijmegen Netherlands
Restoration Jaeger SMR 1224 Rotor
While waiting for finding a spare worm gear , decided to give it a try to repair the broken worm .
Drilled at a lathe 7 mm holes in both ends
Made a 7 mm shaft from a steel bolt .
Put en pressed the parts inline together with Loctite .
And here the result , just have to polish the cracked location .
