RF Distribution from DM8000
jonnymaserati
Dreambox DM8000 with Nabilo Black Hole, 2.0m motorised dish with DiSEqC controler and twin LNB.
Mac Mini with FireDTV S2 and Elgato EyeTV (currently not in use)
Sky+ HD box and subscription (currently not in use as card is in Dreambox).
Syria
hi there
i want to distribute TV from my DM8000 to a TV in another room... i already have a coax cable installed that i was using with my sky+ HD box (using the RF out port which worked great with the IR signal... no messy IR blinkers stuck to the box).
ideally i want something similar for the DM8000, sending the TV signal plus IR signal across the coax... any suggestions for setting this up? i'm assuming i need an RF modulator, but can anyone advise on one that has IR hardware built in since i don't want to have an additional link for the IR signal if i can avoid it! i really want to avoid a wireless IR link, since i have a pair of pyramids but they really don't work well in my current house.
i see in the states that you can get a channel plus SVM-22 or 24 which uses an s-video input (great since the DM8000 has s-video out) and can handle dolby sound which would be perfect, but i need a 220 volt solution. is there a euro equivalent?
bit disappointed the DM8000 doesn't have the RF out with integrated IR like the sky box... it's a really neat solution.
regards...
hi there
regards...
For example: DM8000 baseband into an RF modulator then into a device like a PROception starLINk for RF/IR control. There'll be a list of others that manufacture similar products.
hi there
would still need a modulator to feed this unit? ideally would prefer a combined modulator/IR/distribution unit.
regards...
hi there
regards...
Yes, this particular product doesn't incorporate a modulator.
