Rookie question!
Basmati
10' mesh dish.
Mauritius
Hello,
As a previous Openbox user, I'm having some problems to be accustomed with the DM800se. I want to be able to arrange channels in the order I want but I don't seem to find how to achieve this. Also, I would like the channels to be numbered so that I can recall the channel by their respective number. Thanks.
Basmati
Set a bouquet up and stick all the channels you watch into it. Use Dreamboxedit, and arrange the channels to your hearts desire
So it means I cannot arrange the channels in the Satellite list. The only way to arrange the channels is to set a bouquet? Also can't I do this simple task of arranging channels within the box? Do I need to use Dreamboxedit for this? Thank you.
You can arrange channels within bouquets on the linux boxes ive used but its fiddly and time consuming as you can only move 1 channel at a time
why not just download a channel list and send it to the box using dreamboxedit or enigmaedit
This is what I did finally but honestly, it was easier with openbox as you can do it without having to use a computer.
You can do it on Dreambox without a computer.
After you've made your boquets, just go to the chanell you want to move, press menu, then enable move. Then you can highlight it and move it where you want to.
