From what I understand Saorsat reception is more limited by interference from other spot beams on the same frequency than by signal strength. I would say that if you're receiving Saorsat in any part of Ireland, north or south, you're not likely to notice much difference in reception if you stuck to the recommended dish size. It's reckoned that Saorsats transponder power is currently lower powered than what it could potentially be, some people who monitored early testing noticed it being much stronger than it is at present, so they could be able to turn up the power to compensate for the FEC change.
I'd guess the FEC change is to prepare for RTE1 to go HD on Saorsat, as it has been on Saorview now for a few months with the SD simulcast about to be turned off.
I might get a Saorsat LNB for a bit of messing about later on, but I can already get Saorview terrestrial transmissions fine so Saorsat wouldn't give me anything I can't already get.
