Setup the Dish
Status
Not open for further replies.
INSTALLATION GUIDE
1. You must ensure your wall/ground stand is 100 level on all sides.
2. Connect POLAR MOUNT to wall/ground stand, semi-tighten it, enabling you to move it by hand
3. Bolt on MOTOR ARM between the front and rear of Polar Mount ( multiple holes to fit different bolt size)
4. Release rear clamp of Motor Arm and slide the whole of the arm in or out until polar mount pole
( front) is 100 % vertical, then lock arm.
5. Put your dish on the polar mount parallel to the rear of the mount.
6. Fix your LNB parallel on the boom arm, with the F-Plug connection at the bottom.
7. To align, move whole of polar mount/arm/dish Left or Right to true South/I degree West Satellite.
8. Using the up and down movement of your dish, and left and right of whole polar mount, align for
TV NORGE on 1 degree West frequency 11.421 H until picture is 100. Then lock polar mount
and dish ( TV norge is a decoded channel)
9. Release rear clamp of motor arm, bringing it backwards 1 inch from the end of the outer casing.Then lock arm.
10. When wiring your motor arm ensure the same colour cables go to the relevant connections,
between your motor and receiver-positioner.
11. Set your East and West limits as per your instructions of your receiver-positioner. If your dish
turns East instead of West, go to the back of your receiver-positioner and reverse the two motor cables.
Adjusting the polar mount
If the adjustments are done in the correct order, you can get a dish that tracks just perfect. You should have an unwarped satellite dish, and a straight ground pole, it will make things easier.
1- Start with checking the mounting of the feed horn. All the legs on the tripod should be of the same length. You should measure them, and do any adjustment you can if they are not the same length. Next, you have to check the distance from three different points on the edge of the dish, to the center of the feed horn. Remember, even if the tripod legs have the same length, that does not mean the feed is centered! You might have to "bend" the feed back into center of dish, or adjusting the tripod legs to get the feed centered in the dish.
2- Set the off-set angle on your polar mount (declination). This is an adjustment that tilts the dish *forwards* at an angle of about 4-6 degrees, depending on what latitude you live. You can find the exact angle for your location in charts, but if you set it for about 5 degrees, you'll be close enough to get going. This adjustment is usually done on one of the mounts connected directly to the dish.
3- You then move the dish to the highest point on your polar mount. You do this by using the actuator. You can do this by visually looking at the dish and the polar mount. You are basically centering the dish on the highest point on the polar mount. Now, you have to set the elevation angle of the dish. I like to use a meter for this, but it is also possible to do it without. The elevation angle is about 40 degrees, depending on your latitude. This is not very critical at this point because you will adjust this angle for best reception later. If you measure the angle on the mount, you might have to add the declination angle to get the true dish pointing angle.
4- You need to find a satellite that is located just south of your location. In most cases, there is a satellite close to the longitude you live. A few degrees off will not make much difference because the dish moves almost flat in the center of arc. Try a Ku band satellite because the accuracy is much higher. However, you might look for a C band satellite when you start. It will be easier to find than a Ku band satellite. Having the dish parked at the highest point of the arc, you have to turn the WHOLE polar mount on the ground pole to you hit the satellite. If your elevation was way off, you might not even get a signal. Adjust the elevation and turn the mount again until you find the satellite located "straight south".
5- Fine tune the elevation angle. Turn the mount sideways until max signal and then adjust the elevation angle until its maxed. At this point, you have set the off-set angle and the elevation angle for the satellite at the highest point in the arc.
6- Now, you have to get the dish to track on the sides of the arc. This is where most people fail. DO NOT adjust any elevation angles on the mount at this point! Move the dish using the actuator to a satellite on one side of your arc. You should hopefully see the signal from the satellite, if not, pick a satellite closer to the center of the arc. Peak the dish on the satellite using the actuator. Next, you have to push or pull upwards and downwards on the dish. You don't have to use much force, just a bit to see if the signal gets better or worse when you push/pull on the dish. What you are actually doing is to change the elevation angle a bit. If your dish is pointing at a satellite to the east of center and you have to push up on the dish to get a better signal, then the elevation angle must be adjusted higher. You adjust this by turning the WHOLE mount to the east! You have to use the actuator and move the dish a bit west to peak the signal. You go back and forth until the dish has the correct elevation. Next, you have to check a satellite on the other side of the arc. If you peaked the dish for center, and then for one side, the other side should be very close. This will depend on your ground pole, offset angle/elevation angle and quality of feed/dish.
7- If your dish is not hitting center on the other side, try the same adjustment as above. If the dish needs to be pushed up to get a better signal, then TURN the WHOLE mount in that direction. If the dish needs to be pulled down for a better signal, then turn the mount the opposite direction (towards the higher point on arc).
8- Then, go back and check the other side. Hopefully, you're not far off. You might have to go from side to side before your dish tracks perfectly.
9- If, and ONLY if you can not get both sides to peak, both sides would be too low or too high. You can then do a small adjustment of the declination (elevation) angle to get the two sides into peak. BUT, only do this if you can confirm that both sides are low or high. If the dish is to high on the sides, but fine in the center, the declination angle is to low. Increase the declination and the elevation angle the same amount. They will cancel each other in the center of arc, but track lower on the sides.
10- You should now have a perfectly peaked dish If you used Ku band satellites for the peaking, it will be as good as it can get. If you used C band satellites, you might want to do the same thing using Ku band satellites.
Positioner V-box
This means you can use it with all motors that support the DiSEqC 1.2 system and that are connected only by one coaxial cable. This positioner support ordinary motors since it also has connectors for a reed sensor and for a motor.
On the front the receiver has a three parted LCD display that displays all important information, position numbers and impulse numbers when the antenna moves. On the right somewhat bellow the upper part there are three buttons to control it without a remote control.
One button turns it on and off and the other two turn the antenna to the left and to the right.
On the back there are four spring-clip connectors to cennect a motor, a sensor and grounding. There are also two IF connectors for the connection of a DiSEqC positioner
connect the LNB with a coaxial cable to the positioner and the positioner to the receiver. Afterwards connect the positioner with a four-wired cable to the motor. This way all controlling is done by the receiver and the movements are fully automatic. This means if you change the program on your receiver to a program on another satellite the receiver will send the necessary signals to the positioner so that he’ll change the position.
Memorizing the positions depends on the receiver, but it’s basically always the same procedure. Move the antenna manual till you get a clear picture and memorize the position. You have to repeat this for each and every position.
VBOX
The incredible V Box
for use with the
Humax and other Diseqc receivers.
Enables heavy duty dish motors to be used.
Converts Diseqc 1.2 to be converntional to 4 wire control.
Increases output to 3 amps.
Ideal for properly motorising Diseqc 1.2 receivers. No extra remote needed. Fully automatic.
Available in black or silver.
If you are buying a digital receiver for motorised use, you MUST check this out.
Not required for the Strong 4375 or the Echostar 3600 receivers
as they already have a hardware positioner built in.
Included with our Humax and other CI motorised systems
Status
