Captain Jack
Retired human
- See signature
- North Somerset
In order to progress with my Gibby project, I need to shorten the 18" jack to use it for declination control. So... I chopped it in half and am now stuck.
The inner tube (A) with the spherical joint had a threaded end (C) originally but that's now in the bin. Without the thread, I cannot get the worm drive "nut" (
inside the tube. How do I make the thread? The "nut" is made of plastic, which explains the play in it, and already has some threads stripped. Alternatively, how can I fix it inside the tube? Can I just bash it in with some epoxy and hope it's strong enough to hold it? Wouldn't mind replacing this with a metal equivalent...
Also, the plastic sleeve (D) that sits between the inner and outer tube is knackered. Can I get replacements for these anywhere?
Cheers
CJ
Cheers
CJ
