Shotgun cable
hullaerials
Sky dish and lnb, shotgun cable
Hull, uk
Hello rookie post here, I came across a satellite installation with shotgun cable. I have a question, can I connect just one of the cables to the Freesat port on the back of the TV? Or is shotgun cable meant for a twin receiver? Ty
If it's from a previous Sky Q installation you'll need change the LNB. If it's a universal LNB you can connect just one of the cables, both don't need to be connected.
If it's a Sky minidish and the LNB only has two outputs it's probably a Sky Q wideband LNB.
Thanks, It is a minidish. So I take it I'll need a sky q box to receive any channels.
The LNB on the dish can be changed for a Sky mk4 quad LNB. Alternatively a Freesat 4K receiver will work with a Sky Q LNB.
Sky branded LNB with two outputs is almost certainly from a Sky Q installation. They're both Sky minidishes, perhaps the larger 'zone 2' version if they appear to be larger than other Sky dishes in the area.
