PsiDOC
- Dreambox DM7000:
250GB HDD
256mb USB Flash Numerous Images including patched DM7020.
Astra 2 28E
Pace S*y Digibox:
Standard (No Mods)
Astra 2 28E
Rusty Minidish with Quad LNB
- Wales... Innit?
Features:
* Advanced FIREWALL with graphics start/stop/configuration
* Advanced SWAP file configuration, you can set swap in USB, CF or HDD (16mb or 32 mb)
* Advanced DNS with graphics start/stop/configuration
* Advanced FILES visualizations
* Advanced BACKUP with graphics start/stop/configuration
* Set MINICROND start at any reboot
* Advanced MINICROND system configuration, with more script added (restart cam, restart openvpn ecc..)
* Set SAMBA start at any boot (have to install package)
* Advanced WEEKEPG options ( ..if you want use standard, set to blue-panel->options->weekepg )
(for now log is not possible ..only, option is visible ..for possible future changes)
* Automount HDD USB CF
* Advanced HDD ..set sleep and acoustic options
* Formatting USB (to HDD option)
* Advanced SCRIPT options for personal set
* Advanced OPENVPN with graphics start/stop/configuration (have to install package)
* OPENSSH support (have to install package)
* Advanced DROPBEARSSH with graphics start/stop/configuration (have to install package)
* Color set to RGB from default ( for lcd TV)
* Simple Set directory for picon
* Inserted DM7020 Network Fix
* Reiserfs and Fat32 supported
Display Function:
From 1.8.5 more of this information is settable from Menu-Advanced..
* Set zap without OSD (if press OK return OSD)
* Set OSD always on when OK is pressed (required from nokia9k8)
* Display Snr, Agc, Ber
* Display video information
* Display frequency, polarization, symbol rate
* Display emu in use
* Display service providers name
* Display CaID, ProvID, PID (you can hide from options)
* Display Decoding Source (you can hide from options)
* Display long date format
* Picon, already inserted to enigma code (thanks to jlmota)
* SkinPreview (thanks to jlmota)
* Skin Lite/Full, when Lite ..if no OSD present, and press OK see Full (thanks to tension for help)
* skin by porto for Dreambox
* skin by porto for Ipbox
EMU:
* Set Default CAM
* Set channel CAM
* Set provider CAM
* Stop active CAM
Addons:
* Internet addons download
* Manual addons install
* Remove installed addons
Misc:
* Italian, English language
* Many language in download
* Skin default - porto
* Picon for -skyit+italian channel- is already installed
* Several Plugins/Games/Addons installed
* IPBOX200S have UHF in/out
* IPBOX200S ...for free memory (if is necessary):
1) Go to free channel
2) Click to "Free Memory"
...now is possible to start/stop install/remove visualize script ecc..
The best image I have found for my FTA card. Works superb.
Have uploaded this to my server as it's too big for the file limits that are set here.
_http://www.psidoc.com/dreambox/images/sif_team/SifTeam-1.8.6.7000.img.zip
Regards,
PsiDOC
Display Function:
EMU:
* Set Default CAM
* Set channel CAM
* Set provider CAM
* Stop active CAM
Addons:
Misc:
Regards,
PsiDOC
