SifTeam 1.8.6 [DM7000]
PsiDOC
Dreambox DM7000:
250GB HDD
256mb USB Flash Numerous Images including patched DM7020.
Astra 2 28E
Pace S*y Digibox:
Standard (No Mods)
Astra 2 28E
Rusty Minidish with Quad LNB
Wales... Innit?
Features:
* Advanced FIREWALL with graphics start/stop/configuration
* Advanced SWAP file configuration, you can set swap in USB, CF or HDD (16mb or 32 mb)
* Advanced DNS with graphics start/stop/configuration
* Advanced FILES visualizations
* Advanced BACKUP with graphics start/stop/configuration
* Set MINICROND start at any reboot
* Advanced MINICROND system configuration, with more script added (restart cam, restart openvpn ecc..)
* Set SAMBA start at any boot (have to install package)
* Advanced WEEKEPG options ( ..if you want use standard, set to blue-panel->options->weekepg )
(for now log is not possible ..only, option is visible ..for possible future changes)
* Automount HDD USB CF
* Advanced HDD ..set sleep and acoustic options
* Formatting USB (to HDD option)
* Advanced SCRIPT options for personal set
* Advanced OPENVPN with graphics start/stop/configuration (have to install package)
* OPENSSH support (have to install package)
* Advanced DROPBEARSSH with graphics start/stop/configuration (have to install package)
* Color set to RGB from default ( for lcd TV)
* Simple Set directory for picon
* Inserted DM7020 Network Fix
* Reiserfs and Fat32 supported
Display Function:
From 1.8.5 more of this information is settable from Menu-Advanced..
* Set zap without OSD (if press OK return OSD)
* Set OSD always on when OK is pressed (required from nokia9k8)
* Display Snr, Agc, Ber
* Display video information
* Display frequency, polarization, symbol rate
* Display emu in use
* Display service providers name
* Display CaID, ProvID, PID (you can hide from options)
* Display Decoding Source (you can hide from options)
* Display long date format
* Picon, already inserted to enigma code (thanks to jlmota)
* SkinPreview (thanks to jlmota)
* Skin Lite/Full, when Lite ..if no OSD present, and press OK see Full (thanks to tension for help)
* skin by porto for Dreambox
* skin by porto for Ipbox
EMU:
* Set Default CAM
* Set channel CAM
* Set provider CAM
* Stop active CAM
Addons:
* Internet addons download
* Manual addons install
* Remove installed addons
Misc:
* Italian, English language
* Many language in download
* Skin default - porto
* Picon for -skyit+italian channel- is already installed
* Several Plugins/Games/Addons installed
* IPBOX200S have UHF in/out
* IPBOX200S ...for free memory (if is necessary):
1) Go to free channel
2) Click to "Free Memory"
...now is possible to start/stop install/remove visualize script ecc..
The best image I have found for my FTA card. Works superb.
Have uploaded this to my server as it's too big for the file limits that are set here.
_http://www.psidoc.com/dreambox/images/sif_team/SifTeam-1.8.6.7000.img.zip
Regards,
PsiDOC
hiya but how sit goin' mun whereabouts in wales are you from mun ?
south wales here gwent near brynmawr....
Tried to PM you Jack, but it seems that side of the board has been crippled.
Pembokeshire here. But have some friends very close by to you.
Psi
The ability to PM is related to post count.
If you fill in the vcard in your profile members will be able to email you (settings & options > edit options).
