Cosyslipper
- 1.4 dish with a Re box 5800 receiver
- Spain
is it possible to buy a one in and two out splitter with a on and off switch on the outlet side
That's a good point. You need to make sure that the switch is what is known as a Break before Make type.The advantage of these A/B switches is that you prevent shorting the pin with the ground - who hasn't seen those tiny sparks?
The problem with these shorts is that some tuner cards are quite sensitive and I have blown a tuner in the past.
I got it from Amazon.I use two of these (one for each motorized dish):
I don't remember where I bought them.
I have plenty here, but alas no longer in the EU.Do you mean like this?
Interruptor a / b Satellite en venta - | eBay
Encuentra Interruptor a / b Satellite en venta entre una amplia seleccion de en eBay.www.ebay.es
I don't know why all the hits are for delivery from the USA. I can't believe that there are no companies in Europe that can supply these. There must be some other description that is in common use that I don't know.
Can I have a couple of these? Will be useful to switch between all the receivers and dishes here.I have plenty here, but alas no longer in the EU.
10 Euros each plus postage.
Advice Needed Post in thread 'One For The Switch Men'
Some A/B switches are better than others, in terms of positive contact once pressed (for DC throughput), isolation and shielding.
I created a thread somewhere on the switch internals I have here for distributing HF / VHF around the house
Of course, PM meCan I have a couple of these? Will be useful to switch between all the receivers and dishes here.
