Archived-1
Persona non grata
- uk
Hi, I have just ordered the above box, is anyone using one please, if so what's your thoughts on the box and what image are you using.
No blindscan on the Nano. The hardware is not capable.I am reading good reports on the openvix image so I have downloaded the 3.0.808 file,
Thanks to all for the work on this image and thanks to Huevos for his work on blindscan this is important to me.
Sorry, but changing skin cannot change the button mapping. A skin is just an xml file that controls presentation, and a directory of images used for that presentation.The open vix image that came on my Duo was just awful.
It was badly written - changing the skin on it changed the key mappings.
BTW, I've got a TM Single which is almost identical to the Nano.Hi, I have just ordered the above box, is anyone using one please, if so what's your thoughts on the box and what image are you using.
Yes its a sata 2.5 Huevos, yes I read in the spec that a caddy is needed, but its half the battle having a spare hard drive,What hard drive is it? If it's for internal, it needs to be 2.5" SATA and requires an optional caddy.
Thank you Huevos, I have a 4gb and a 1gb, I will pop out tomorrow and get another 4gb.Well follow my advice above about the USB stick, especially while there is no hard disc fitted as you don't want the EPG writing to the internal flash (as AS found out with the Duo).
1GB would be ok for flashing images. Images are less than 100MB.Thank you Huevos, I have a 4gb and a 1gb, I will pop out tomorrow and get another 4gb.
You simply put the image on a USB stick, plug it in. Turn off and on the box at the back/mains and you'll be asked whether you want to upgrade the software. Press Ch- button on the front and that's it.I have flashed using ftp ? I think it was before, is this possible with this box please, I know it took me a while to do it at the time but I got there in the end, but I will be taking the easy route even if it is possible for the time being.
