Titanium Recovery Tool
Status
Not open for further replies.
rolfw
Believe it when I see it Admin.
Staff member
Promax HD Ranger+ spectrum analyser.
Derbyshire
This utility has had a fair degree of success, but of course you use it at your own risk.
Translation of Readme
Good, the purpose of this small program is to try to recover the ATR to those cards that are it "lost". The program which does is to make a Reset to the card, and next send the same Worm that envia the SorryShackes, that is to say, makes just like if him dieramos to the flechita and the Disable (but with this metodo but the probable thing it is that it leaves a callus to us). The ATR Resureccion estara sending the Worm and making the Reset, until the ATR is the correct one. Once of correct ATR, the program will stop, and you dira that the card has recovered. Greetings East NaSeR P.D. program is even a Beta, if encontrais algun failure or what is, please to say it to me.
Sorry to say that but these Tool dose not work with some cards.I have a Blue tit and it dose no help for me.
Best Regards
TazzMan
HI i get an error :
system error & H8007007E (-2147024770) cant find modul ? (Das angegebene Modul wurde nicht gefunden)
plz help me i use xp
This software WAS used for recover the ATR in Nagra Rom3 cards.
It does not work with Titanium Cards.
It is not useful any more...
Pity
Seems strange that 5 people have voted that it has worked with their Titanium.
I'm Sorry, but it's true.
This does'nt mean that sometimes it works.
The ATR resureccion.exe was made to automate the string that the program Sorry Shakes 3.1.1 sends to the Rom3 card whet it was update to the version 377:
ROM 3 DISABLE BUGCASTERS and then RESET.
Sometimes you need to push those buttons hundreds of time to recover the ATR from the card.
Probably the string it sends to the card could recover an ART form the titanium, but i think that it is impossible.
Do you have a link for it annimal?
Thanks to mohsintunsi
In the little recovery proggy (I have the spanish version); you have to check the right com port (1 or 2) to which your programmer with titanium is plugged and select the phoenix mode 3.68. The readme text isists that it has to be 3.68 and not 3.57. Then; all you have to do is start the recovery by clicking "rescucitar" ("recover") and wait until the program stops. The text says the recovery is not guaranteed but it shouldn't take more than 3 minutes. Give it 5 to be sure. Then try to erase your card. If it doesn't work with Titanium prog 1.10.2, try earlier versions. Mine was finally successfully erased after three or four trials with various versions. Good luck!
I mistakenly thought I had a problem with my white titanium's ATR (it was brand new), as I couldnt find any OS or ATR using the 1.10.12 progger. So I tried running this recovery tool and now I have what seems to be an infinite number of different ATR's on the card. I've been erasing for hours now, using TMB 2.6, and have gotten virgin state lots of times, for different ATR's (OS 0, 9.4, 0.8). But I still cant program any files onto it, and at the moment I just continue erasing in the hope of finally resetting the card. Consider this a warning, but help/recommendations are also very welcome. Btw, TMB is the only progger I've found that can erase, though the bananaprogrammer can identify ATR, Oh yeah, I am using a smartmouse /phoenix programmer with 3.58/phoenix setting.
bundu
i download the Dynamite programmer!!!does work with the infinity phonix??been trying but not luck!hope some one can help resolving the no atr problem !thanx
Hi Folks
Does this work with White Tit cards?
[I have two which will no longer programme - whilst my two Blue ones are fine]
Thanks in advance.
John A
Status
