dafydd
- Technomate 5402, CM 1.2, V-box, Linux computer
- Flintshire, North wales
My vbox (actually labelled Gbox) packed up with a puff of smoke! Opening it up the screws were so tight that the plastic case split in various places. I discovered that a disc capacitor across the output of the 36V rectifiers had gone short circuit. The transformer primary appeared open circuit. With nothing to lose I stripped the tape from the transformer only to find a fuse which was O/C. Shorted this out, replaced the capacitor and the rectifier diodes (which measured OK but looked cooked). One of the spring clips for the motor connection had disintegrated, so the wire was soldered in place. Superglue on the case, and it now works!
And this is where I need advice!
I have another box, marked PR1000, which is immaculate, but occasionally when moving will not stop and drives all the way to the limit. I have opened it up and checked the board for dry joints or broken tracks - everything appears OK. Without knowing the firmware and an oscilloscope I don't know how to fault-find it.
