Vlf
Channel Hopper
Staff member
UK
Following on from the AM radio list thread (moved to this section last night), a link for those with a few reels of insulated cable doing not a lot.
abelian.org Home Page
The potential link between ELF/VLF and the ULF (0.01 - 10 Hz) as a precursor to an earthquake.
https://ee.stanford.edu/~acfs/LomaPrietaPaper.pdf
This ties in with research carried out on the effects of the sun's magnetic field(s) on our planet, carried here by the solar wind.
Inequality of the interplanetary current sheet and the movement of the Earth as it orbits through open or broken sections of the interplanetary magnetic field are further compounded by the reversal of the Sun's magnetic polarity - twice - during each solar cycle.
One of the scientific instruments on the Parker Probe in determining how better to measure the changes remotely, which might lead to a reliable warning system. The trouble is the speed at which a repeatable result of such a low frequency can be reported before the impact.
http://cds.cern.ch/record/118596/files/CM-P00068442.pdf
Noises from the Jupiter system are on the rise, peaking in June.
The 20MHz band has become somewhat polluted lately though, thanks in part to cheap LED lighting
