vma
- Main dish: 120cm No-Name, Motek SG-2100A, Bullseye LNB
- Portugal
Hello everyone,
I’ve just published a new specialist tool:
VMA StreamReader CLI
https://vma-broadcast.com/wp-content/uploads/2025/04/VMA StreamReader CLI - 20260226.zip
(The link may change once I add it officially to the Download page and start refining it.)
Every exported function from streamreader.dll can be called directly from the command line.
Additionally, I added one extra helper function:
which forwards the TS to UDP.
It follows the philosophy of tools like FFmpeg or TSduck.
You interact directly with the DLL.
This allows:
It lists all available commands:
Example:
No GUI logic. No constraints. Just DLL-level interaction.
CPU usage is extremely low.
It works well as a minimal TS forwarder.
First of all
This tool is dedicated to our dear CrazyCat — I sincerely hope he is alive, well, and still pushing RF boundaries somewhere.What is VMA StreamReader CLI?
It is a 1:1 command-line frontend for streamreader.dll.Every exported function from streamreader.dll can be called directly from the command line.
Stream(UDP,ip,port)which forwards the TS to UDP.
What does it enable?
It provides direct, unfiltered access to streamreader.dll — without CrazyScan, EBSpro, IQmonitor, VMA Stream Reader or other UI constraints.You interact directly with the DLL.
This allows:
- Manual tuning experiments
- LOF / LOFSW boundary testing
- Raw RFScan / BlindScan experimentation
- Direct capability verification
- Comparing behavior across different DLL versions
- Very lightweight TS streaming
- Automated batch experiments
Usage
If you run it without arguments:streamreaderIt lists all available commands:
****** CrazyScan StreamReader CLI - 20260226 ******
(C) 2026 VMA-Broadcast - VMA Broadcast
Available commands:
ListTuners()
CheckForDVB()
CheckForDVBExEx()
StartDVBEx(index)
StopDVB()
SendDiSEqC(type,data)
SendDiseqCmd(byte1,byte2,...)
SendDiseqCmdEx(byte1,byte2,...)
SetPol(pol)
SetChannel(freq,sr,pol,fec,lof1,lof2,lofsw)
SetChannelEx(freq,sr,pol,fec,lof1,lof2,lofsw,mod)
SetChannelExEx(freq,sr,pol,mod,lof1,lof2,lofsw,std,pls_mode,pls_code,mis)
SetChannel2(freq,sr)
SetChannel2Ex(freq,sr,pol,mod)
SetChannel2ExEx(freq,sr,pol,fec,mod)
RFScan(freq,pol,lof1,lof2,lofsw)
BLScan(freq,range,pol,lof1,lof2,lofsw,minsr)
BLScanEx(freq,range,pol,lof1,lof2,lofsw,minsr,std)
BLScan2(freq_start,freq_stop,pol,lof1,lof2,lofsw)
AirScan(freq_start,freq_stop,step,bw,std)
SignalInfo()
SignalInfo2()
GetSignal()
GetSignalEx()
GetSignalExEx()
GetSignalStrength()
Statistic()
FFTInit()
FFTScan(freq,pol,lof1,lof2,lofsw,range,mode,acc)
FFTTerm()
IQScan(input,count)
IQScan2(input,count)
CIRScan(hiRes)
SetFilterRaw(pid)
DelFilter(filterNum)
SetBBFilter(is)
GetMAC()
GetCaps()
GetTunerType()
GetEEPROM(offset,length)
SetEEPROM(offset,byte1,byte2,...)
PLSSel(mode,code)
MISSel(enable,filter,mask)
ModSel(mod,pilot,frame,...)
ModInv(waitMs)
Stream(UDP,ip,port)
Example:
streamreader StartDVBEx(1) BLScan(11401000,30000,1,9750000,10600000,11700000,1000) Stream(UDP,239.1.1.1,1234)
You can concatenate commands:
Argument validation
If you provide incorrect arguments, it tells you exactly what is required:
streamreader StartDVBEx(1) RFScan()
Error: RFScan(freq,pol,lof1,lof2,lofsw) requires 5 arguments
Example:
streamreader StartDVBEx(1) RFScan(10891000,0,9750000,10600000,11700000)
RFLevel=-50
Practical Applications
Hardcore DX Testing
You can now:- Replace streamreader.dll with custom versions
- Modify streamreader.ini
- Test LOF / LOFSW bending tricks
- Validate driver behavior across versions
- Compare tuning sensitivity without GUI interference
streamreader StartDVBEx(1) RFScan(11725000,0,9750000,10800000,11750000)
Lightweight TS Streaming
If your interest is the transport stream only, not the RF analysis:
streamreader StartDVBEx(9) BLScanEx(10891000,30000,0,9750000,10600000,11700000,1000000,0) Stream(UDP,127.0.0.1,1234)
Important Notes
- 100% free
- Not part of VMA Video Analyser Package
- Fully standalone
- No DRM
- Pure utility tool
Feedback Welcome
I am very interested in feedback from:- DXers
- Blindscan experimenters
- Anyone comparing different streamreader builds
- Anyone pushing unusual LOF configurations
- Anyone testing MIS / PLS / S2X behaviors
Examples
