XCAM update order - is there any?
CB65
Technomate 5400 CI+ USB, 70CM Motorised dish, XCAM, Infinity USB Pheonix
Panasonic Freeview
Dorset England
Can anyone help with updating my XCAM please.
Today I updated from 1.04 to 1.082 - using clear.bin first, then .bin and finally the softcam.key. Then I updated to 1.095, but there was no softcam.key file. Should I be updating in a particular order or should can I use the sequence I describe.
I've also noticed that on some channels, N*gr* I think the picture keeps freezing intermitantly.
Damhay
Thanks, I have located the latest softcam.key file and will write it to block 14, but my question is still. Do I have to programm the XCAM with every update file in sequencial order from 1.05 to 1.095 (quite a lot of files) or can I just load the latest 1.095. I don't know if every programm overwrites the previous or wether some just update a bit?
1.095 claims to be 100% all working, but for example when I input the latest 0065 cyfra+ keys, or 0064 Digital+ nothing clears.
Any advice gratefully received.
Seca2 is not available on the xcam without an official card as far as I am aware which is why even with the latest version that you cannot get the D+ or Cyfra channels.
As for the firmware, i suspect that if you have 1.095 loaded with no problems and working then you have done all of the nessisary updates.
